Hi all,
So I finished my 1x build (7970 di2 10 speed, SRAM 52T narrow wide chainring) and everything works perfectly apart from my smallest sprocket. When pedalling the 11t the chain jumps and upon further investigation it appears that the chainline is causing the chain to rub on the next sprocket up and it 'catches' and jumps sporadically. I can make a small adjustment to move the chainring out a little with spacers in the chainring bolts but I am already concerned that the chainline in the biggest sprocket is too crossed, fixing the 11t will make the chainline even worse on the big sprocket.
Has anyone else had this problem?
Thanks
Thanks
