Mulen wrote:
1. Sealant: Is there a Best-Practice or fastest sealant out there? Or is it the clasical trade-off with "fast sealant is less puncture resistant" ?
I've tried a ton of them at this point...and I find myself continually crawling back to Stan's begging forgiveness like a wayward lover returning home. Stan's just has a great balance. Seals pretty well. Lasts a good while.
The weakness I find in many is being too thick. Thick is great when the sealant finds its way to the hole. Often it appears not to. The very viscous Stan's will immediately find any hole, and because it's so viscous it tends to squirt out quite a bit, but will eventually usually seal up small holes.
Quote:
2. Pressure: Can I assume that I can use the Silca calculator for this setup? Its giving me 94 PSI for 25 mm, which I find more than I expected TBHThere is still conflicting evidence on this front, but other credible sources corroborate the Silca ballpark. I don't think you'd go far wrong with Silca. I typically go to the Silca # on the gauge, and figure the loss of air on valve disconnection and natural small seepage over time will lower it just a bit, and I don't stress over that.
Quote:
3. I see some of the Pros are moving away from Tubeless?? (Skipper, etc) - do we know what latex tubes there are running?
Can of worms question, but here we go: Why are they moving away from Tubeless? And what consequences do that have?
I have no idea why the pros would veer away. But as a pure TTer, and a huge road tubeless fan, I also very often run latex for my race TTs.
1) I only use the race wheels for races. So it's tedious to do a tubeless setup, race it for an hour, then the next day clean out the sealant so it doesn't dry out in my race tires before the next TT. For "A races" I will set them up tubeless to protected against flats. I never carry a flat kit for 40K TTs. If I flat, my race is done.
2) If a pro gets a flat and it it seals at suboptimal pressure early in a long course bike leg, say <50PSI, they're probably going to stop and do a tube swap anyway. In training, I'd stop, throw in some bacon, and try again. I could see a pro just going straight for the tube option and not risking a second stop in case of bacon failure on a sliced tire.
3) Flats in pro-grade races are pretty rare?
The big payback for road tubeless is (IMO) from daily riding/training.
