jcbesse wrote:
I guess it depends on the wheel as well. With 23mm or less internal rim width you should be able to run 28mm tires. Not so sure with larger internal wheels. Pretty sure 30mm would not fit.
(I did use the combo 303s with 28mm schwalbe pro ones for a bit, and it worked but was tight to the point that my lbs wasn't happy about letting me do it... I since moved that wheelset to my road bike and use either swissside or aerocoach wheels on the px)
I have Enve 6.7c witch is 25mm internal, with 28mm tires , have tried both conti and pirelli, both works great
