mathematics wrote:
99.8% efficient at 1:1 ratio, so a locked hub same as a normal one. 99.2% when the internal parts are actually spinning. I'm not a fan of stating these numbers in such a way, as they are largely speed-dependent and not nearly as power-dependent. 1000W up a low speed hill climb is going to make any setup look incredibly efficient, percentage-wise. A 100W descent is going to make the best system look horribly inefficient.
In the white paper it more clearly states these numbers in a more digestible way: 2.49W loss when the hub is 'active' v. 0.52W when the hub is locked. It makes a lot more sense when stated like this. I'm taking them at their word for the testing numbers as food for thought, but obviously it would be good to have third party testing as well.
The tests shown were on the order of 10min in length, presumably in laboratory conditions. My worry with this setup is not the initial performance, it's the tiny gear teeth and their wear rate, especially if any contamination is let into the hub. There's 6 tiny teeth taking the entirety of the load that are going to wear out, contamination is going to get in, etc. I'd be more interested in an efficiency test after 1000 miles of road riding.
https://acrobat.adobe.com/...aVerb=group-discover I struggle to see how this is "better" than 2x.
You lose the weight of the front derailleur but gain the weight of the classified, so a wash. One less chainring however.
You save a few aero watts for no front derailleur but you lose 2.5 when hub is active, very close to a wash, maybe slight savings
Since you are 1x up front, you have very slight loss in chain line efficiency, probably taking back the previous savings
You have a custom cassette. No big deal but definitely not a pro
I think shifts are cleaner than shits on the front derailleur so a slight advantage there.
Currently a proprietary shift button but they say this will be resolved.
You bring in maintenance and wear unknowns.
Extra cost.
What am I missing ?
