Quote:
So I'm getting an itch to get a aero road bike and was looking at the Canyon Aeroroad. I have a Speedmax CFR small and a Cervelo R5 54 with S/R of 548/380. Anyways the Canyon site suggested that I needed a XS which has a S/R of 521/ 378. The S has a S/R of 539/390. Are aero road bikes supposed to have a different stack and reach numbers compared to a regular climbing bike?
Old lungs,
The difference between a climbing bike and an aero bike probalby has more to do with weight than geometry. Your prefered bike position (aka fit) should be replicated across your road bikes.
I think you're off to a good start. You have a current bike (upon which I assume you like the fit) and that bike has a Stack of 548 and Reach of 380. Well the size small Canyon Aeroroad has a Stack of 539 and a Reach of 390. That's the closest. Now you need your "front end configuration": #of spacers between stem and top of head tube, stem length, stem pitch, and bar reach.
The cockpit on the Aeroroad (CP00018) is a 90mm stem with a 39cm wide bar. I don't know bar curve. I think there's only 15mm of spacer height capable under it.
So it becomes a bit of a math problem to work back what you have now and how you have to tweak the front end to get the hoods to arrive at the same spot.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
