PRFour front brake routing
Hi everyone
I picked up a PRFour frameset in a sale and I’ve been building it up
I’m struggling to get the cable routing on the front brake through. I got the cable up through the fork and into the base bars, but in order to fit the usual 1m front brake cable I had to make the angles very tight and now the inner cable won’t go through
Does anyone have a PRFour and could post some pictures of how their brake is routed?
Re: PRFour front brake routing [glenjamin] [ In reply to ]
I had similar issues on my x-pr. I ended up routing the inner cable with the basebar removed from the stem to get rid of the tight bend between the basebar and stem. Once the inner cable was through, I then put tue basebar in the stem and tightened it.
Re: PRFour front brake routing [khanlon] [ In reply to ]
oh! that's a great idea - i'll give that a go
On that question, to remove the basebar to swap stems, do I undo the cable at the brake lever or the caliper? I hate bringing my bike to the shop to adjust my stem height as I am dialing in my position.
Re: PRFour front brake routing [davegibb26.2] [ In reply to ]
I would take it off the caliper and out of the fork. But its up to you what you think is easier.
