rmt wrote:
playguy wrote:
10 ironman races and tons of miles since my surgery many years ago. Knees have never been better. Find a good athletic based surgeon and get it done.
Rehab now starts within a day to 3 post surgery and I was able to run within 2 weeks. That was years ago and now the PT has started far earlier. Good luck, but I'd suggest getting out done ASAP.
Just a warning that this isn’t always the case. I was expecting this, but the surgeon discovered once inside my knee that rather than cutting out the damaged meniscus he could stitch it back together, which should give a better long term outcome. The downside - 3 months of walking in a straight leg knee brace. I was able to ride a bike on a trainer after about a month though. The upside - I made a 100% recovery and 12 years on the knee is good as new.
My wife has had surgery for meniscus tears in both of her knees. Each time she went in expecting a quick recovery and then, after surgery, was told she had to be non weight bearing for 3-4 weeks. This was because the cartilage damage was worse than the MRI showed and he did a procedure called "microfracture". She can still bike without any problems but her running days are over.
If you have the type of meniscus tear where your knee locks up, or its causing terrible pain, then you really have no choice but to go with surgery. If its doing neither of these then its worthwhile to consider physical therapy. If surgery is done, the surgeon can either repair the tear (if its in an area with good circulation) or cut out the damaged area. If the damaged area has to be cut out, there's no longer cartilage protection at that area and you may be at increased risk for an early end to running (if that's what you like to do). Cycling would likely still be fine.
