I have Zipp 404 Clinchers on a new C'Dale IM 1. Will the presta 48mm valve tubes work? Or do I need longer stems?
Re: Zipp 404 Question [strongontherun]
You will need longer stems or the extensions that screw onto the presta valves that Zipp sells.
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
What is the rim depth?
would you be so kind as for send me a couples of photos of your bike?
Thanks
Thanks
Re: Zipp 404 Question [kdw]
Vredenstein have an 80mm valve option available on their tubes thats what i use,also conti have a presta valve extension 40 mm both work better than the zipp option.
