Re: Do you use a wetsuit in Oly dist? [Endorphinjunkie] [ In reply to ]
....which leads me to another question, I am swimming with a buoy all the time right now because of a recent acl surgery, and am swimming times close to before when I would kick, is that kind of like an equalizer?
Re: Do you use a wetsuit in Oly dist? [leon] [ In reply to ]
Depends on what your race goals are!
An assumption on this forum seems to be that we should do whatever is necessary to make us faster.
However, if your goal is not speed, but comfort and a good time - then base your decision on how warm/cold you want to be and whether you are more comfortable in a wetsuit or out.
Even with a well-fitting wetsuit (a new thing for me) I still feel a lot more comfortable without one. Without it, I experience the water a lot more directly. It is like a wilderness experience. Except for the thrashing people all around. The only race I intend use the wetsuit for this year is Alcatraz, plus any others where the water is below 62 degrees or so.
Re: Do you use a wetsuit in Oly dist? [Oleander] [ In reply to ]
In Reply To:
I am doing Alactraz as well, wouldn't dream of jumping off the ferry without a suit! I know people who do it, but they are nuts. I like pain but not that much.
I ride a Cervelo...get over it....
I will be using a suit for the first time in April. I guess from these posts I should use the body glide stuff?
Re: Do you use a wetsuit in Oly dist? [trying to tri] [ In reply to ]
In Reply To:
Try some open water swimming first, see if you get chafe anywhere....I have body glide in my bag but have not used it, but I see tons of other people lathering themselves up in that stuff maybe just as a precaution....
Wear it.....you will be faster......or less tired.
I shall never misuse Rex Kwon Do
I shall be a champion of freedom and justice
Body glide on neck is my recommendation...but even without it, you'll live....
