lyrrad wrote:
Pull harder, the kick does whatever it needs to balance it.
If I swim 50m, then yes I consciously kick harder, my roll is a little less and there is no glide, the catch happens as quickly as possible if somewhat messy.
50m also creates a quite noticeable wake that I can kick in and the body feels to tip forward and roll downhill.
Kicking is used as a mind trick to key the high turnover, but once out to 100m then I simply do not have the speed/stamina to swim like that, the wake is not big enough to milk energy out of and I basically use the long distance stroke with less glide.
When training I will often put on some flippers to do long distance at race speed and kick just enough to keep the pace at race pace so I can train limb speed for fast swimming but at less exertion and far more time on task that is also race speed specific.
I see no value in slogging out KM's at a slower hand speed as that just trains you to swim slow.
So when not doing intervals and doing a long swim, I like the flippers to keep the muscle speed the same even if just cruising.
Which is one reason why I think pull buoys are plain waste of space for full stroke swimming.
There is nothing that it does that is specific to proper swimming.
It inhibits roll, kicking, makes stupid body position and robs you of the natural feel for body position.
OK, I thought that I was the only other guy on the planet that never uses a pull buoy and would rather use fins to swim "at speed" with proper kick timing/counter balance of the arms.
