Evening all. When I acquired my Felt IA 10, I found that it had some custom work done to it. Specifically, the aerobar armrest pads were screwed into a small square extension plate (steel) that had four holes in it. Two for the aerobar armrest and two to mount into the aerobars itself which is a Pro missile carbon evo.
Here are some pics of that mod:
The goal, seemingly, of this mod is to spread out the armrests a bit. Being broad shouldered, I really like the way this feels. And even though the basebar (on the missile evo) has another set of wider holes, that would be too much...this little maybe 3/4 inch adjustment is just right.
I have two issues:
1. The dang armrests keep bending down given the extra leverage created and the crappy textured slider insert on the aerobars. I think I have a solution for that that involves some carbon paste and better grippy stuff.
2. Here is what I'd like to know from you all...i'm not in love with the very rough cut and drilled steel plates...they are ugly and heavy as hell. And they are both shaped differently...sort of like someone in a shop grabbed a flat piece of steel did a rough cut and drilled some holes.
Ross, the owner of Hart's Cylcery in Pennington NJ showed me a beautiful set of billet aluminum prototype spacers for just this purpose but I dont think he manufactuers them. And really I don't need much...a small square, like 2"x2" of a stiff material with four holes drilled (can spec it out more precisely later).
Does anyone know of a pre made solution here? THANKS!!!!
My other car is a Felt. DFL>DNF>DNS.
"There will come a day you won't be able to do this, today is not that day."
I have two issues:
