mknight84 wrote:
Doing my first build and I am just waiting for the handlebars to arrive. Anyways do I need to use barrel adjusters for the derailleurs? I would have to use inline if needed because of my frame. I would prefer not to have to use them but it is my first build so maybe I should. I do not have any for my shiv except what is built into the components. Shimano 105, 5800 is the groupo of that makes a difference.
I've had them in the past on bikes, and I never ended up using them. I suppose if you had a mid-race wheel change, maybe it could be used for on the fly adjustment of the rear derailleur, but that's gonna be pretty darn rare occurrence, and you could still just take a few seconds to hop off and adjust the barrel on the rd instead. It's also another piece to introduce a little bit of cable drag along the housing.
As for the front der.. If you've set it up properly to begin with (cable is stretched and FD adjusted when first installing), that should really never need to be adjusted.
.02..........
