Tony5 wrote:
Here are a couple of troubleshooting:
- See if another watch/bike computer can connect via Ant to P1's - Check using PowerTap app that both pedals are on the same version of firmware. Some require you install on each pedal -Crank length set -new batteries and choose the Altkaline as it is recommended -battery cap is tightened sufficiently (PS, they have replaced some battery caps in earlier models that corrected an issue some people faced. I'd drop by and show a power tap rep if they are around to make sure) -Finally, remove all sensors on watch, and repair only the ones being used for race day, and try pairing outside away from interference Not alkaline, use Lithium batteries.
BTW, the powertap app is still iOS only...no Android.
My bet is either:
- The batteries died during transit and you need good batteries - lithium
- The pedals are fried and need service
- Something is wonky with calibration - you can individually calibrate each pedal through the app or at least see if one is working and the other is not
- FW is weird - if he tried updating them and they stalled halfway, need to retry in the app
