I wonder if your short run in period of the chain would be better if you first cleaned the chain. When I clean a new chain, especially Dura Ace, they are a ton of small metal filings left in the mineral spirits. I can't image letting that crap roll around in there is helpful, though it might not do too much damage.
Re: The most detailed chain lube testing document I have ever seen - Ceramic Speed UFO Drip [dkennison]
Re: The most detailed chain lube testing document I have ever seen - Ceramic Speed UFO Drip [grumpier.mike]
All that stuff is terrible and that is what continues to wear out the chain and maintain friction as the chain streatches over time.
It's just a continual grinding of high points.
The 5 minute initial run in we do is an attemp to get the really high peaks knocked down/offso to give the chain a chance otherwise to deltas would be unrealistically high. That is primarily for lube testing.
For finish optimized chains it just to free up the wax.
Dan Kennison
facebook: @triPremierBike
http://www.PremierBike.com
http://www.PositionOneSports.com
Dan Kennison
Re: The most detailed chain lube testing document I have ever seen - Ceramic Speed UFO Drip [Slowman]
Slowman wrote:
so, degreaser, alcohol, done. yes? anyone have a different formula? i help it out a little with compressed air, just from my presta adapater. otherwise, no quarrels.
Degreaser
Wipe
Alcohol
Wipe
Mineral spirits
Wipe
Alcohol
Wipe
Rock n roll extreme
Wipe
Install
Lube
Wipe
dkennison wrote:
For your use I would just use a partially fill plastic jar "like penutbutter" for both and shake.no spray bottle? mini hudson sprayer?
Dan Empfield
aka Slowman
In the past I just added some degreaser or alcohol in the jar, added the chain and shake.
Dan Kennison
Dan Kennison
dkennison wrote:
In the past I just added some degreaser or alcohol in the jar, added the chain and shake.ah. well. yes. but that requires taking the chain off the bike. i like the connex link (and the sram link) because i can do that. but i'm lazy and i will do that only so often. i want to clean my chain more often than i want to take my chain off the bike.
Dan Empfield
aka Slowman
dkennison wrote:
So your saying you don't like my answer :-) A few years ago I just took a rag and kept turning the crank until I got most of the black off and added lube.
Same here, except I spray WD-40 into the rag first to create a small "saturation spot". That's the part that gets wrapped around the chain lower run as I turn the cranks backwards.
I actually do this after each ride (takes all of 4-5 seconds)...keeps the chain cleaner overall between lube applications.
edit: I don't like applying degreaser and such to a mounted chain due to the difficulty of removing all of that. WD-40 is basically a small bit of silicone lubricant in a volatile solvent. The solvent/rag combo do a good job of removing the external "grunge" and the only residue left over is going to be silicone lubricant.
Wiping off the dirt in this manner prior to re-lubing (typicall RnR Extreme, a drop on each roller) keeps the chain and gears reasonably clean, while also apparently extending life. I typically get ~4k miles on a chain before I see any measurable elongation (using a 12" rule), at which point I replace.
I personally think people get a bit too concerned about cleaning the bushing/pin interfaces. If you minimize the dirt residing on the chain, then not much actually gets in there to create "lapping compound" in use...
Re: The most detailed chain lube testing document I have ever seen - Ceramic Speed UFO Drip [Tom A.]
wow. you wrote WD40. in conjunction with a bicycle. boy are you in trouble now.
Dan Empfield
aka Slowman
See my edit above.
WD-40 has many purposes in regards to a bicycle...one just has to remember that it's mostly a solvent, with a small amount of silicone added. For the purposes of cleaning a chain (at least keeping the outside clean), or displacing water from various areas after a wet-down, it's a great solution. Rely on it as a primary lubricant? Not so much...
BTW, I've often cleaned off the thick factory chain grease by putting the chain in a zip-loc bag and spraying it down with a bunch of WD-40. It dissolves away most of the grease, but leaves a small amount of silicone in place. It definitely cuts down on the thick "grunge" that forms if you don't remove the grease, and I don't have to worry about removing any de-greasers or any sort of multi-step baths. Seems to work well...
See my edit above.
i'm just giving you the business. i have arrived at the same solution you have... so to speak.
Dan Empfield
aka Slowman
Slowman wrote:
See my edit above.
I see what you did there ;-)
BTW, if you're not part of the solution, then you're part of the precipitate :-)
dkennison wrote:
For your use I would just use a partially fill plastic jar "like penutbutter" for both and shake.I use an old gummy vitamin jar.
Slowman wrote:
here's a question i have had and since all the friction propellerheads are here, maybe i can ensmarten myself. what do you use to clean/prepare your chain for lubrication? tell me the steps you take before you squirt your squirt?
I would say that the Molten Speed Wax recipe is the go to reference https://moltenspeedwax.com/pages/clean-your-chain
I clean and wax the chain for its initial use and then just do follow up applications of Squirt lube. Until I have the need for another round of cleaning/waxing.
I use the Wd40 on a rag to occasionally clean any dirt/dust off the outside, but once your entire drivetrain is waxed, it really doesn't build up that nasty layer of black goo you get from "regular lubes". I can handle any part of my drivetrain and not have messy hands. The best part is that there are none of those little black grease spots on the carpet. The wife used to get really POed about those
Slowman wrote:
ah. well. yes. but that requires taking the chain off the bike. i like the connex link (and the sram link) because i can do that. but i'm lazy and i will do that only so often. i want to clean my chain more often than i want to take my chain off the bike.If I'm using a regular oil type lube (last couple of years Morgan Blue Race Oil), then I follow the "pro mechanic" routine:
Bike in stand.
Take off wheels, put some cardboard underneath the bike.
Install chain keeper.
Put Morgan Blue chain cleaner in jar, use their brush to apply to chain, pulley wheels, chainrings. Watch crud fall off onto the cardboard.
Remove cardboard, spray bike with Motorex bike clean. Wait a few seconds, then hose and sponge the bike. Let it drip dry, then use a rag to help dry the chain more.
Meanwhile, do similar cleaning with Morgan Blue/Motorex for the sprockets/wheels.
Everything then spotless. Wheels back on, lube chain.
Pretty fast and undemanding once you're practiced.
Re: The most detailed chain lube testing document I have ever seen - Ceramic Speed UFO Drip [sebo2000]
sebo2000 wrote:
BryanD wrote:
https://issuu.com/ceramicspeed/docs/cs_hr?e=30940316/52702676 Discuss and debate this document.
anything with UFO in title make me giggle.... :) NASA, Navy seal, Delta Force.... Space, F that
Here is what I use:
https://www.amazon.com/DuPont-Teflon-Chain-Saver-Self-Cleaning-Lubricant/dp/B00KMMFE8Y
1. super clean, you can touch it after 100km ride and you will not have a mark
2. perfect for Road, Cyclocross, track, wet, mud you name it, your bike can be covered in mud but chain will be ultra clean, mud and hydrophobic.
3. Super easy to apply, no mess
4. Inexpensive
Interesting...I usually have a can of the DuPont Multi-Purpose Teflon lube on hand for dry-lube applications like Speedplay cleats and the like. I wasn't aware of this version. Looks like they add Molybdenum to the mix...and that there's a 4 oz. liquid dispense bottle available.
Hmmm...I might have to play with some of that...
Re: The most detailed chain lube testing document I have ever seen - Ceramic Speed UFO Drip [duncan]
Duncan;
I have not tried the connex chains yet; how do they compare to shimano sram or kmc? What is the durability of the chain and the coating? How does the coating deal with rain and wet weather?
when do you think your coating will be available?
