tri@thlete wrote:
Power match is an awesome feature, but when I used it with Stages, it didn't work very well and very spikey (definitely compared to my current Quarq). Plus, it was a lot lower power than Neo. The main issue was that there wasn't a consistent number that Stages was lower, so it was hard to understand the calibration. For example, at 100-130w, Stages was almost the same as Neo, 130-160w, it might be 10-15w lower, at 200-230, it might be 25-30w lower. Thus, I got crushed on any harder intervals.
If you are using Stages, I would just use Neo for your power source then figure out what Stages says outdoors and see if it matched. Or just go with your P1's if they are more consistent and sell the Stages.
Need to try that to see if I have the same issue with Powermatch. P1s unfortunately are not mine.
Paulo Matos
