hubcaps wrote:
I just did Mt Evans coming from sea level. From what I've read Pikes is a bit harder than Mt. Evans. It was one of the most difficult bike rides I've done, but epic. I'm roughly a 3.5 watts/kg FTP. I was fine up to about 12,000 ft. I rode an older CAAD9 and swapped it with a compact crank. I should have swapped the cassette too. I also did a 10 mile run the day before, so that probably didn't help.
Pikes peak is much harder than Mt. Evans. The day after the national hill climb I did. 110 mile ride from Littleton to the top of Mt Evan and back. Awesome ride. I switched back to the 11x28 from my 32 for Pikes. I may have even swapped back to the 36 small ring I normally ride. That was fine for the Evan ride.
Referring to another post Mauna Kea is WAY harder than Evan or Pikes Peak. Probably at least partly because you been climbing at least two hours before it gets hard. That and the fact that it is really f'ing hard...
Kevin
http://kevinmetcalfe.dreamhosters.com My Strava
