Hi,
I replaced recently my front brake (TRP T922-1) due to scratches and I have problem balancing it. Even when screwing completely the right screw and un-screwing completely the left screw, I didn't get a correct adjustment. It behave like both spring didn't have the same tension.
I'm pretty sure I have mounted them correctly. I have been paying attention to use the left spring with left side caliper and the right spring with the right caliper. I verified also that the adjustment screw is working (internal plate didn't slip).
I wondering if some of you already see/fix that.
Thanks,
Fred
Thanks,
Fred
