BMC TMR01 or TMR02 are great bikes from my experience, the TMR01 tested right up there with the best current Road Aero Frames. There was only 2 things it did not score great on - 1 - As with most Aero frames they right a bit ruff compared to a standard frame, I solved this with 27mm Tubular tires on wide carbon rims. 2 - Some people don't like the brakes, mine are set up right are work great, but if you plan to swap rims of different sizes often you may want to get the TMR02 with the exposed fork brakes.
Tour Mag Aero test 2016
I got my BMC TMR01 with Di2 as a lightly used dealer demo bike for $2k, sold off the wheels, bars, seat and such then used that $ to buy the parts I wanted. I have seen used BMC TMR02 going for for $1500.
Here is myTMR01 as it is now at 15 lbs ......
[quote="farm_lim"]how it was graded
overall test results
aero test results. blue= stock wheels, black= 404 firestrike standard wheels for all bikes.
interesting note, cervelo blends well with hed clinchers 9blue bar) but not that aero with zipps.
in alphabetical order
[/quote]
