Tom_Hughes wrote:
Do tyres have stall angles like wheels?
Specifically I have a well worn 25 GP4000s on the front, with the flat worn section in the middle, when the wind picks up it seems to suddenly stall, or thats what it feels like!
Does this actually happen or is this all in my head?
Yes. It's dependent both on tire wear and on the rim it's paired with.
I.e., you are exactly right that a well worn tire is going to stall earlier - MUCH earlier - than one that is not worn. Especially on the front. And you certainly can feel it, especially on deeper section rims. In Zipp's own testing (done by Josh Poertner), a 23mm GP4000S with 500mi was no better than any other tire, which is a huge contrast to a new tire which blew everything else away.
Certain tires also pair better/worse with certain rims. Continentals are fast with pretty much everything, but there are other tires that only work with with certain rims.
