SWoo wrote:
Off topic, but what would it mean if I can get my left arm behind the back fully, but cannot do it with my dominant right arm besides obvious flexibility difference?
Not sure really, ignore that post. As Jason said, that level of flexibility isn't important. It's a pretty difficult injury to nail down. I've had a few different opinions and I never really go to the bottom of what caused it. It's better now, not 100%, but close. My technique has changed and I think that has helped. I don't know what part of the stroke was causing it to be stressed. I used to have a thumb entry with both hands, fixed that, but the injury didn't go away. Paddles definitely made it worse and therefore swimming with fingers apart alleviated the pain, less pressure. A lot of the stretches didn't seem to help a whole lot, especially the rotator cuff band exercises I was given. If anything they seemed to make it worse.
https://www.physioadvisor.com.au/wp-content/uploads/13846256300x300.jpg I do a bit of light stretching now, but no band work. Swimming with a high elbow and really engaging the lats seems to greatly reduce the load on the shoulders. Although when you get to the point they are quite sore, I don't think there is anything you can do that will eliminate the pain i.e you can swim with perfect technique and the pain will still be present, which can be confusing because you then start thinking that you're still not doing it right, which was the case with me. Now my technique is much better, the pain only really returns when I'm tired and my technique gets sloppy and that's only really at the end of a hard 5km+ session. It's a tricky, tricky injury though and reading about it on the net will send you lala.
