lyrrad wrote:
Your hand is already an incredibly sensitive force and flow meter.
A good feel for the water is when you can tell you have all the angles right and you are getting maximum lift and minimum drag possible.
Your hand is, and mine is pretty good. But for the adult onset swimmers in my classes, I disagree. And not all of them obviously, but I have folks who for example can't scull for the life of them, just flat out can't do it. Changing the path of their pull from a semicircle to a somewhat straighter path - can't be done.
As for this device, it is similar at its core to the aquanex system Rod Havriluk has used for years. While I have my problems with some of the stuff that Dr. Havriluk puts out, I wouldn't call it useless.
For this item and others similar ones, to me the big challenge will be for a given swimmer - trying to figure what he SHOULD be doing - without following a dead end. As you point out, if a swimmer decides to get higher force from his palm but in so doing puts his forearm in a suboptimal position - then maybe that's a short term win but long term loss.
On one hand, the sort of analysis needed to figure out the true factors of what separates a swimmer from being a better swimmer is easier now than ever before in terms of the mathematics of it - Excel now has classifier analysis as an add-in. but the hard part of getting hundreds of people using the item and recording the resulting data is going to be the long pole in the tent.
