I've searched, but can't seem to find answers that fit.
Looking to switch from Adamo to Sitero. Well, to try and see how it goes at least. Mainly am looking for an option that spreads the pressure points better than the Adamo.
The Sitero seems good, first impression, but I need to get it set up properly.
I've not found instruction that says what is the recommended tilt for the saddle. With the Adamo, their instruction is to have the saddle rails be level, which then gives a bit of tilt if you put a level on the saddle, back to front.
Is that the same recommendation for the Sitero? Or do people just play with it until something feels right?
Second question would be, if others have made this switch, where did you end up positioning the Sitero fore/aft compared to the Adamo? Going by some recent fit work, seems like the Sitero needs to come forward more than the Adamo to get the same relative position on the bike. Did others find this also? If so, how much? (I am looking at like 3cm more forward)
thanks for any input.
