GreenPlease wrote:
Slowman wrote:
Okay. Thx. Didn't brr show the power comp as slightly puncture resistance tho? Vs 4000s2?
Identical on the tread, worse on the sidewall iirc. Considering the uncertainty around the aerodynamics of the Power Competition, the logical choices are either the GP4000 SII where the aero likely washes the crr hit and you get better sidewall protection or the GP TT which probably has equivalent aerodynamics but better crr (TT has better sidewall, worse tread puncture resistance... sort of a wash).
For myself, personally, I'm sticking with GP4000 SIIs. The only tire that sways me is Vittoria's new tubeless Corsa Speed. According to Xavier (AeroCoach) they are "incredibly aerodynamic" when paired with the Jet+ rims. If that's true, coupled with their very low crr, it could be... very very fast.
...however, the idea of putting those tires on and taking them off makes me shudder.
I've taken a Corsa Speed on and off a Hed Jet+ Black wheel a couple of times now...it requires a lever for the last bit going on (with most clincher tires/wheels I can do totally by hand), and metal levers are a good thing to have to get it started off, but it's not nearly the death struggle some other tubeless tires can be <cough...Hutchinson...cough>.
My issue with it is getting it to seal and hold air when set up tubeless...it leaks down worse than a latex tube inside. I've noticed some sealant "weeping" from under the sidewall coating (i.e. through the casing), so maybe it's just going to take a few days for the sealant to help things out.
For now I'd take those statements from Xavier with a grain of salt...he mentioned 2 other things at the same time that had me scratching my head. First, he said that a certain tire INCREASED Crr with wear (something I've never seen)...and secondly, he said the Corsa Speed rolled faster with a latex tube than when set up tubeless. I found no difference between the 2 conditions on my roller tests (makes me wonder if his tubeless setup was leaking air fast during the test!) So, that doesn't really give me much confidence in the veracity of the aerodynamic claim on the CS/Hed+ setup.
