A friend has a Cervelo P3 which comes with the stock 3T Vola aerobar set up. The arm pad on this bar is only a very thin 10mm, which she finds uncomfortable after serious distance. (Profile's standard is 16mm and they have a 21mm available) The 3T site only refers to a "Comfort Pad" set up for all shapes and does not give a thickness measurement which leads me to believe this is all they have. Cee Gee does not show a replacement for the Vola (which surprises me given the popularity of the P3). Does anyone know of a thicker replacement pad or a proven fix for this problem?
Re: Any thicker pads for 3T Vola? [trimule]
https://www.ceegees.com/product/?product_id=140
Description says it will work with the Vola.
Favorite Gear: Dimond | Cadex | Desoto Sport | Hoka One One
Re: Any thicker pads for 3T Vola? [The GMAN]
Gman - Thanks for that tip. I had completely misread that listing (referring to the 2012-13 P-3 etc.) and looking at the illustration (which didn't match) I assumed these Volas were a different shape. Sloppy work on my part -sharp on yours. Thanks again.
x2. My 3T Brezza II Limited from 2010 came with really crappy pads. I upgraded to the pillow-like CeeGees. Awesome stuff, worth the aftermarket price.
Or this model...
http://forum.slowtwitch.com/..._or_similar_P6463744
Custom made if you need.
http://www.baron-noir.com
