Question for the geometry buffs...
You're designing a custom tri frame, stability is the goal here. You have the choice of slacking the head tube angle to achieve a longer wheel base/front center or increasing the fork rake and using a slightly steeper head tube. The logical answer is to use a fork with 0 rake so you have the most amount of mechanical trail, correct?
Thanks
Jonathan Blyer,
ACME Bicycle Co., Brooklyn, NY
Thanks
Jonathan Blyer,
