pmcdc wrote:
lso if you're even remotely prone to motion sickness, ………….. and sit up top
yes. up top. in fresh air.
peggy
(Long time diver) Best place on a boat if you are prone to sickness is at the stern (rear) at the bottom deck in the open air if you can get outside, looking to the horizon. The Ultramar ferries at least have this area open as I recall
The worst place to go is up, you will have much more movement - in all directions - the higher you go.
Ditto on the bus, did it a couple weeks ago both ways. It does add about 2 hours to your trip - small wait for the bus, bus ride, variable wait for the ferry (we had to wait an hour - there are two companies (actually three now) and they used to alternate hours, now they both go the same time, ferry ride, cab ride. Also means you need to leave about 5 hours before your flight back to accommodate travel and two hour arrival at CUN
For the boat - Don't buy round trip tickets. Just buy them on the return. Used to be a bigger deal when the boats ran alternate hours , but schedules change all the time, easy enough to buy one way.
Alternate is you can arrange a van ahead of time for a pickup. The IM Coz facebook page has contact info if that's of interest.
Last, you can often find a pretty good deal getting back with a driver in a/c, they want to get back to the airport so you can likely find it for cheaper than the bus (or as cheap).
Have fun, great race.
