Clutch Cargo wrote:
I did it with a QX1 6870 GS RD
There two holes fro spring tension in the RD set it to the stronger one.
Also with the Q ring the chain tension will slightly vary because of the ring shape.
Make sure you set the right chain length.
Oval rings do not vary tension at all.
There is always 180 deg or so of chain contact and that is always half of the teeth on the ring.
The only thing that happens is that the chain will rise and fall with the changing diametre.
Sometimes this can be harmonic with the length of the chain and set up an oscillation that can throw the chain off when combined with an external force like a bump with a slight sideways component in it.
The chain tension only varies on the driven side to match the changing leg inputs throughout the pedal stroke, just like a normal round one only different.
The non driven side is a constant of the rear derailleur spring.
