What do you think? It seems like the tubes with long valves are generally more expensive. Using valve extenders - if you think they work well - would give me more tube options too, not to mention being easier to find.
Re: valve extenders v. long valves [morno]
I've done both. The long-valved tubes work much better. Adding an extender just creates another junction that can (and often does) leak.
While we're on the subject of extenders, in situations where you have no choice but to use them (tubulars with deep-dished rims), valve extenders that insert between the valve body and the valve itself work MUCH better. The valve itself protrudes from the rim rather than the extension. You just have to remove the valve core. I haven't had any trouble with leaking air using these. With the more common type of extension, you wind up having to use teflon tape to enforce the seal. I've found them to be very unreliable.
Re: valve extenders v. long valves related question
A freind of mine was advised not to put the nut on the valve or the cap. in case of flat you don't want to be messing around with those. what is the purpose of the nut or for that matter the cap?? I had always put them on becuase that's how the bike came.
Re: valve extenders v. long valves [jaylew]
I gotta disagree with jaylew. I like the simple "tube" extensions. The nice thing about these extensions is that they don't interfere with the factory valve core/body junction. There is also just a single seal that could leak, that being the factory valve core/body junction. When you use the extenders that go between the factory valve body and core, you now have two seals on the extension.
Yes, they can "leak", but that's just when inflating the tire. Not all of the air from the pump ends up in the tube. (Although I still have no problem inflating this setup with a single CO2 cartridge) But they have no impact on whether or not the tube will leak air through the valve. Since these extensions hide the valve, you have to leave the valve unscrewed and you can't deflate the tire without removing the extension. This bothers some.
I've found tube extenders for my Hed's to be a total pain in the *ss. You lose them, they leak, etc.
Re: valve extenders v. long valves [cerveloguy]
Re: valve extenders v. long valves [Pooks]
This is too funny. Who ever thought people could get passionate about valve extensions?? Anyway, I've never had problems with the tube extensions, although I do get some leakage while pumping but that has never bothered me. I don't use teflon tape. For some odd reason I also have peace of mind using these things. (I still question these types of extensions contributing leaks since they should have no air pressure in them.)
I've used the type of extensions you prefer only once and they just seemed like more hassle to me. I guess it's good that they make both types, that way we're both happy.
I use valve extenders on my HEDs and have no problems. Pump up the tires the night before the race, and a quick recheck before I leave for the race. So far I have never had to repump a tire the morning of the race. I use teflon, only because that is what was suggested to me from the previous owner of the wheels.
Letting air out of the tire with a valve extender can be done by using a 2mm allen or a spoke.
Reverend Dr. Jay
Lake of the Pines Triathlon fastest bike course record holder - Golden State Super Sprint fastest tri course record holder - Wildflower Long Course slowest run course record holder (4:46:32)
"If you have a body, you are an athlete." -Bill Bowerman
Reverend Dr. Jay
