In Reply To:
In Reply To:
So is the notion of the top of the front wheel "throwing" air forward off base? Or is it just that -- since the point of air friction contact at the top is the tire (not the rim) -- all similar tires-on-rims will test pretty much equal in this regard?
Aside from the whole rotating/non-rotating thing, I found that I was able to draw a solid conclusion WRT the potential magnitude of the tire width effect. There was a measurable difference in the samples I tested - it might surprise some people how much this stuff really "matters".
As far as the "throwing air forward" concept, I think that for the rim/tire, the rotation detail is a second order effect which contributes to the skin friction drag - since it effects the velocity gradient around the rim/tire. When you start cramming this into the confines of the fork crown, things might start to get interesting - but if you widen the fork crown to free this up, you pay a penalty in frontal area, etc.. These are the details that the fork design experts are paid handsomely for (well, it is the bike industry, so not too handsomely) ;-)
Wheel aerodynamics are dominated by the translational component of velocity, not the rotational.
Thanks again, Kraig. I think your final sentence is the bottom line, eh? Interesting that rotation is a second order effect.
You mention possible widening the fork crown to free this up. The ad copy Oval uses for their new Jetstream fork claims benefits from a different approach -- it was actually the contention made in that copy that I cribbed for raising this sub-topic, as it struck me as interesting (
if true). FWIW:
"The top of the wheel and fork area is the primary source of aerodynamic drag on the bike except for the rider.
A. The spokes on top of the wheel are moving twice as fast as the bike. Wind hits the fast moving spokes creating turbulence (which means drag). That is a bad thing.
B. The paired aero shapes of each jet stream fork leg create a vacuum effect, sucking the turbulent air from around the spokes, compressing it back into a laminar flow and accelerating out the back of the fork. It's optimized 3-to-1 aspect ratio minimizes the fork drag. These are good things.
C. The laminar flow exiting the rear of the fork is directed about 15° outward from the spokes behind the fork, reducing the drag effect of these fast moving spokes. This is a good thing..."
I edited the final sentence of this, as it literally reads "This is a goof (sic) thing" on their site. :-)
My e-mail address is in my user profile -- would be interested in just your gut reactions to this approach (either here on this forum, or privately and off-the-record via e-mail).
