as we've discussed before, for an athlete of good or better back flexibility, its probably only below-waist size that matters for CdA, so weight by itself doesn't tell you a lot. i will grant that disproportionate shoulder width is likely also relevant since it directly impacts frontal area and the ease of getting the arms to precede rather than "side-car" the torso.
my main cycling partner, despite being the same weight as me, is about an inch taller and has legs that are probably 3-4" longer than mine, along with less back flexibility than i do. that seems to be worth about 20W when we ride. the difference is clearly CdA, clearly not weight. so yes, size matters :)
