Any tri guys using the Crono Elite Fluid? I have had good service from the service on my Mag trainer with the US service out of Washington State.
The crono adjusts based on your weight, etc; was wondering if anyone here was using it and how it worked with aeoro bars.
tks in advance.
JG
i'm using the primo fluid wireless. its pretty much the same trainer as the chrono but has the wireless computer. the gel roller is quiet enough to listen to the tv without cranking the volume. pezcycling tested mine a while back. I like it but the bike tends to rock a little bit more than a standard framed trainer.
http://www.pezcyclingnews.com/?pg=fullstory&id=4487
I have the elite fluid (with a couple of others types as well). I have not found it that good, as the load does vary quite a bit depending on where you sit. I does have great load (you can really wind up the load), but the variability in load really annoyed me, and it was quite hard to ride smoothly, or repeat a certain load. I hope the go back to fixed load and move away from the weight based flex system.
