My brother recently got the Garmin footpod with the Garmin 305. He is having an issue and I was wondering if anyone here has heard or experianced anything like it.
After purchasing and activating a foot pod for my 305, it appears that for any indoor activity when the foot pod is not on, I get no data points. I believe this is the only correlation. I use my 305 when lifting weights and that's the only time I turn the foot pod off while indoors. When I do that, the unit records the correct workout time, the correct max and average heart rate, but no data points, so that my graph is a straight line from start to finish. I have no problem with the unit when the foot pod is on, or when I'm outdoors using the GPS. Is this a known issue?
I believe this is the only correlation. I do record my weight lifting workouts under "Other", however when I forget to reset the category while running, I've recorded some runs under the "Other" category and they've worked fine. Only weightlifting with the foot pod off seems to fail.
Anyone?
~Matt
Anyone?
~Matt
