Post deleted by Administrator
Re: Ghetto pickup truck rack (photo) [Martin C]
I prefer to put bikes in the back of an Expedition. The bikes stand up and you don't have to take the front wheels off.
Count me as ghetto then. I used that set-up for a couple of years before I sold my truck. Worked just fine.
While we're sharing money saving tips, here is my homemade solution to an endless pool:
You've been hangin' out in Cecil County too much!!
-----------------------------Baron Von Speedypants
-----------------------------RunTraining articles here:
http://forum.slowtwitch.com/...runtraining;#1612485
I have a similar item in the back of our truck for trips. Actually, the clamps is exactly the same, I just used some old boards that were about 24 inches wide and heavy enough to counterbalance the bike. It works fine and cost $10.
I've done almost the exact same thing, works great.
Write "Yakima" or "Thule" on there with a marker and nobody will know the difference ;-)
Any potential issues with large road bumps and vertical displacement of the racked bikes?
Behold the turtle! He makes progess only when he sticks his neck out. (James Bryant Conant)
GET OFF THE F*%KING WALL!!!!!!! (Doug Stern)
Brevity is the soul of wit. (William Shakespeare)
Good call!
I did almost the same thing, but i used a sack of fertilizer to weight it down.
I probably need the other 2 boards and turn the thing around.
I built the exact same thing for my Explorer. Used a 1x10 and cut it to fit the profile behind the wheel protrusion. Covered it in a black carpet, and it looked very nice.
Re: Ghetto pickup truck rack (photo) [Spranger]
Spranger - don't turn the bikes around. They're drafting the cab. That's good. I got a similiar setup. Martin, don't forget the bike lock on your BoM list. ;-)
One cannot enlighten the unconscious.
Stuff that rocks: <fawning links here>
Mine looked a lot like Sprangers before i sold the truck. However I used a piece of 2x8 pressure treated plank and screwed two sections together, very heavy, never had issues with it moving. I also bought some 1 in aluminium stock and made a couple of wheel holders. Just measured and bent it with a vice and a mallet into two flat bottom "U"s, I Dremeled some slots in the top then just drop the skewer in the slot and tighten it up. Worked great. I just tore it apart a month or two ago. haven't figured out what to do for a new setup yet but i saved all the parts.
Jim
**Note above poster works for a retailer selling bikes and related gear*
Jim
Looks good, way better than my single board duct-taped to the truck bed.
I used a piece of plywood about 2 foot by 4 foot. One mount on each end on opposite corners. Then I place the board across the width of the bed. This holds both bikes in front of the fifth wheel hitch. The bikes do not bounce and travel unstrapped, but will be locked if left unattended.
I use various other Ghetto methods of traveling with multiple singles / tandems / or the triplet (and at 10 feet long it is an interesting carry).
tooslow
tooslow
My bedliner has a built in 2x6 "pocket" that I mount the board into vertically with 3 fork mounts on them. It's out in 10 seconds if I need the full bed.
Works great.
______________
HEDmafia.com
Works great.
______________
HEDmafia.com
Re: Ghetto pickup truck rack (photo) [parkito]
I have my "bike board" that I used to move around to use in either my old 1st generation 4runner or my Tacoma. Anyway, you can also run a bungee cord from one of the tie downs, behind the fork or forks and then to the tie down on the other side. I also bungee the seat stay to the rear tie down and my bikes stay put.
Now I have a campershell on the Tacoma with a bed rug so I just turn the handlebars, push the bike next to the side of the bed and use one bungee to hold the bike tight. Works great.
56-11...the only way to fly
That's the way we mounted ours. My husband actually just attacked them right to the truck and we also have one on the tailgate so when it's up you can actually put three bikes in the back. Super handy when bringing other bikes to races.
Lana
Lana
i've done that for a long time - works great
