Headset troubles
I just installed a new Easton EC90 fork that uses their new Easton headset adjuster. This device sits between the stem and headset and expands to tighten the headset. Problem is that it won't stay tight. I assume my stem is migrating up the carbon steer tube and loses the tension. I am afraid to tighten the stem any more and crush the steer tube. Anyone else have this problem or have a solution? Should I just use an expansion plug instead of or in addition to the head set adjuster? Are their certain stems that work better with carbon steer tubes than others?
Thanks for any advice!
Re: Headset troubles [jacksonk] [ In reply to ]
Yep, that "beartrap" thing is a bit problematic. Ditch it. Use an expansion plug. I believe FSA makes one that will fit.
thought it was just me that could never get that easton adjuster to work!
agree the best solution is to use an expansion plug for carbon steer tubes.
My favorite ones are made by Reynold's. They're easy to adjust and hold securely.
-Darrell
