I'm selling my 2014 Shiv. Recently, it has been sitting at my LBS collecting dust. It does have Di2 (10 speed) but currently not functioning properly. It had been working fine but none of the batteries would hold charge very long. Took it to the LBS and they said it was a "junction box malfunction". I am selling everything in the pic except the wheels/cassette/tires, pedals, saddle, and Di2. If you think you can make the Di2 work, you can have it along with the frameset module.
Asking $2700
Size 61cm (XL)
TECHNICAL SPECIFICATIONS
FRAME
S-Works FACT 11r carbon, FACT IS construction, crosswind-optimized airfoils, 1-1/8" lower bearing, OSBB, Control Tower Fit System, Fuelselage Integrated Hydration System
FORK
Specialized FACT Aero carbon
HEADSET
1-1/8", hybrid cartridge bearings
STEM
Shiv Aerostem
HANDLEBARS
Specialized Carbon Aerobar (I changed these out to Bontrager chicane bend but can include original if desired)
FRONT BRAKE
Specialized Aero, side pull
REAR BRAKE
BRAKE LEVERS
Shimano Di2 TT, w/ shifter extensions
FRONT DERAILLEUR
Shimano Dura-Ace Di2, 10-speed, braze-on
REAR DERAILLEUR
SHIFT LEVERS
Shimano Di2 TT
CRANKSET
S-Works FACT carbon, 53/39T
CHAINRINGS
53/39 TT
SEATPOST
Shiv Aero, FACT Carbon, +/-12.5mm and +/-37.5mm setback
Asking $2700
Size 61cm (XL)
FRAME
FORK
HEADSET
STEM
Shiv Aerostem
HANDLEBARS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
Shimano Di2 TT
CRANKSET
CHAINRINGS
53/39 TT
SEATPOST
