Selling an awesome Quarq Sram Red Power Meter crankset. 53/39 chain rings 172.5 crank arms GXP so it will work on all framesets. In excellent condition. With new firmware will now operate without cadence magnets (using newly released accelerometer based cadence). I used this with both DURA ACE and SRAM groups and it worked great. $1000 USD paypal
The SRAM RED Quarq power meter is a lighter, more accurate power meter completely integrated with the philosophy and performance of SRAM RED.
The RED power meter features Power BalanceTM and OmniCalTM and comes equipped with SRAM’s X-GlideR chainrings. Integrated electronics minimize interconnections and reduce exposure to the elements, bringing unmatched durability and reliability.
Installation and operation is a breeze with the LED that signals power on and set zero, clearly visible ANT+TM ID and tool-less, user-replaceable CR2032 battery.
Paired with SRAM’s RED groupset, the RED power meter gives you the professional’s tool set; everything you need to win at any event anywhere in the world.
Features
ANT+TM ID is clearly visible to aid pairing
LED indicator signals power on and set zero
Replaceable battery is a cycling industry standard CR2032
Power Balance™: Uses crankset torque to display the ratio of power generated in the right drive stroke (first half) versus the left drive stroke (second half) for each crank revolution
Omnical™: Power measurement is independent from chainring selection. Swap chainrings without impacting accuracy.
Features
