Classifieds
Post deleted by codec
Re: Profile parts - CarbonX1.5, Cobra base bar, QS2 carbon brake levers [codec]
bump
CarbonX1.5 have been sold
Who picked these up?
send me a message i have some questions about how the bars were cut - was looking to do the same to mine.
________________________________
53-Racing
53-Racing
you achieved to put the brake levers in the cut carbon x1.5 ???
Re: Profile parts - CarbonX1.5, Cobra base bar, QS2 carbon brake levers [kimaswan]
Re: Profile parts - CarbonX1.5, Cobra base bar, QS2 carbon brake levers [Elie_53]
I did it to mine but I had to sand them (the base bar and also the QS2 brake levers) I spent about 3 hours while watching tv!) and it fits but while I was screwing down the levers in the base bar, it cracked (you may have seen that there is a hole in the carbon just near the bent and I cut too near from that hole). Anyway, the carbon is still very solid and I raced many times like that. But it's not as a clean work as I wanted.
I wanted to know whether the seller also sanded it or if he just figured out it wouldn't work and never tried.
I was worried about the cable routing hole too......
hmmmmm mmmm
53-Racing
hmmmmm mmmm
53-Racing
Thanks for the bump guys as the Cobra base bar (with upturns cut off) and QS2 carbon levers are still available.
As for your question, I used a file to smooth out the exterior and open up the interior of the brake lever interface (I used both QS2 and other levers). Then, I drilled new holes for the brake cable routing. The set-up on both Carbon-X and Cobra base bars were solid and I never had a problem with them. Hope that helps.
can you post of picture for me of where the cut is on the bar with relation to the cable hole? I would appreciate it!!!
Thanks!
53-Racing
Thanks!
53-Racing
