My point was that (with the present designs) you can't have four controls with only 2 places to put them.
OK my mistake, the pictures on the other forum show the brake levels. But there are no shifters....
So it is a good idea but you are getting back to using a $300-500 combined shifter brake lever set different from the standard production configuration that clamps onto a drop bar. That is a bit of a technical hurdle. The best course is probably for the designer to revise his bar end such that existing technology (bar end shifters and brakes) can be applied at the end of 1 bar. Something akin to a hose splitter (y-configuration) would probably be the best bet. However there does not seem to be an elegant solution that can be provided at a reasonable price point.
More challenging I think will be providing the required rigidity in the pursuit bars when they need to pivot. this will require some crafty gearing within the bar which will add weight and make it difficult to run the shift and brake cables anywhere but on the outside of the bar.
to me this seems a much better idea for TT on a fixie than in a tri setup even if they can overcome the rigidity/stability issue.
Run like you stole something
Formerly Fueled by ZYM
