In Reply To:
Which set of cables are you using? The internal or external kit? The difference will be the size of the connectors.
If you're using the external kit I wouldn't recommend running it internally at all as you will need to make pretty large holes in order to get them through the frame. The internal wiring kit has cables that are a little longer and will connect to a junction piece.
You're correct with the drilling other than that. Drill behind the head tube and expand the area around the BB for the front der. For the rear der. I would run it externally as the hole at the drive side dropout is closest to the cassette and thus not conducive to running the wiring internally.
On the P4 and S3 the hole is towards the outside of the frame which makes it much easier to run the rear der. wiring inside the chainstay.
Let me know if you have other questions.
Hi Darrell,
Thanks for sharing all your builds.
Just a few questions re drilling. It appears from the pictures on your website that more drilling is required....
Starting at the front end:
Drill just behind head tube to insert __________ cable? (What cable goes in there, is it just the battery)
Drill in between bottle mounts for the battery cable to come out of the frame?
There is then a cable coming from the battery down on the left hand side of the bike - where does it go, is there any drilling required there?
The photo of the bottom of the bike is all blury so can't see what occurs underneath the bottom bracket.
There must be a point where the rear der and front der cables juncture with the battery cable? Where does that happen?
I wonder if you could basically describe what happens from the hole just behind the head tube and back from that point.
(also have you seen the new Shimano PRO Missile EVO bars and stem, that should be good for cleaning up routing of the front end cables etc.)
Thanks again, sorry for all the pestery questions, but considering doing something like this myself and can't find anyone else apart from you that's done it. Even the distributor here couldn't provide any assistance.
Cheers.
