Classifieds
Post deleted by brian1986
Re: WTB: Zipp 10 sp spacer and brake pads [brian1986]
Make sure you get the right thickness (Sorry- I don't have the specs). I used a "regular" spacer I had used on other wheels and it was just a little too thin for the Zipp which caused a slightly loose cog fit when the lock ring was tightened. This caused a loud clank every time I hit a crack or bump in the road. The thickness difference is only 1 or 2 millimeters but it is vital. LBS had a selection of sizes.
Re: WTB: Zipp 10 sp spacer and brake pads [trimule]
Thanks for the heads up, I'll be sure to double check that.
brian1986 wrote:
Thanks for the heads up, I'll be sure to double check that.You don't specifically need a Zipp sapcer... cheap as can be.
http://www.ebay.com/...?hash=item2a512d7d7f
Re: WTB: Zipp 10 sp spacer and brake pads [Donzo98]
Are these spacer legit? lol. Any problems with them?
ErickBar wrote:
Are these spacer legit? lol. Any problems with them?LOL... It's a SPACER...
How non-legit could they be??
