Lightly used SRM pro wired. 175mm crank arms. +/- 2% accuracy. Campy Square taper BB compatible. Looks brand new with absolutely no marks on it what so ever.
There is a tiny crack in one of the bolt holes, but SRM confirmed that this will in no way affect the function or accuracy of the SRM.
You can easily swap crank arms to different lengths or to be compatible with Shimano Octalink by buying new arms from SRM or ebay.
The zero offset is extremely stable at 466 Hz. The factory slope is set at 19.5.
$520 + $15 shipping (I can add a cable set for $30)
Powertap SL (wired) laced in to a Reynold DV46 carbon clincher rim. The hub is from 2007, the rim was laced on in the beginning of 2009.
The unit works, but it has been reading low for a while so if you want accurate readings you will want to send the unit in to Cycleops to be checked and refurbished.
Included is the head unit and 2 wiring harnesses. The freehub is Shimano/SRAM compatible.
This is a great wheel, I just dont have a use for it any more because I have switched to crank based Power meters.
$500 +shipping.
PM or email capink@msn.com for pictures or any questions.
chase196126: Dec 21, 10 0:55
