Oval concept stem and aerobar ext
Oval concepts stem 120mm with 1 1/8 and 26 (undersize claim) I used it with the A900 series aerobars USED
Oval concept double bend aerobar carbon extensions: Going from tip to tip (diagnol see picture) they are exactly 1 foot (12 inches). The body straight section is 6 inches. These easy fit the shimano bar end shifters. There are a few cosmetic scratches at the end of the bars but no damage to the bars. These can be used for internal routining of cable (hole on underside)
PM me for pictures (too big to post and got to learn to shrink them) and prices
Looking to clean out the closet
thanks
chris
Member HED, Cervelo, De Soto Mafia
Re: Oval concept stem and aerobar ext [Koncity] [ In reply to ]
bump
Here is the information on the double bend carbon extensions
  • Original three position aero extension
  • Allow short, high leverage position for climbing
  • Allow two long, low positions for descending
  • Pre-drilled for internal cable runs
  • 295x22.2mm tube with 2-30 degree rises
  • PPA carbon construction for strength and lightweight
  • Alloy front cap for shifter expander
  • Available in clear coat carbon
  • 110 grams
make me some offers
bump for pictures
Added more items [ In reply to ]
Also added
Omega Juicer 1000 with filters and citrus juicer
here is the info:
Omega's original juicer. Model 1000. The model 1000 is durable, efficient, and easy to clean. It extracts 20% - 30% more juice than most juice extractors. An optional citrus attachment converts model 1000 into a professional citrus juicer. Optional filter liners make the model 1000 the easiest to clean. [/url]
Efficient 1/3 HP Induction Motor
250 Watts
Optimum speed of 3600 RPM for peak efficiency
Heavy Duty 1½ lb. Stainless Steel Blade and Basket
12½ lbs
8" W x 9" D x 12½" H
Omega Juicer Model 1000. Retails for $200. Juices fruits and vegetables, Stainless Steel Basket, High Powered. Juicer cleaned after every use and still in like new condition
Comes with:
Original box and instructions
Over 500 filters (3 bags of 200 with one open) really saves time on clean up to seconds retails $36.00
Citrus juice attachment (retail $39.99)
First 100 get everything. Please email me for pictures or questions.
