Kask Bambino. Venge ViAS 58cm. Tarmac Disc 58cm. 177.5 DA SRM. Moots RSL. Vector 2 pedals.
Okay....need to clear some stuff out of the garage.
Kask Bambino, Medium red with white stripes and clear lens. I decided I prefer a different helmet and I don't need 2 TT helmets for the 2 or 3 TTs a year that I do. Original cost was $500. Looking for $200 shipped, paypal gift. I have cleaned it since the last use. The only flaw I can see is that there is a little bit of rough patch on the bottom of the lens where it would touch my cheek. So minor that you cannot see it in pics.
2016 58 cm Venge ViAS rim brake. Bought as Pro model but updated with Di2 to mostly S Works spec. $5800. Fit on this bike is complicated, so we will need to talk to make sure it is going to work for you. Original cranks will be put back on. Cranks and pedals not included.
Garmin Vector 2 pedals. The wide crank version...fits Specialized cranks. New in box as these were a warranty replacement. $700.
Wahoo Elemnt. SOLD.
Zipp 202 Firecrest clincher wheels.--SOLD
Zipp 303 Firecrest clincher wheels. 11 speed. SOLD.
Hed H3. SOLD.
DA7800 SRM, wireless, for $400 shipped. 177.5mm cranks and 50x34 rings. Extra $50 gets you the PowerControl 6. The battery was dead after sitting for a few years so I had it serviced by SRM recently. Cranks are in great shape, with almost new rings. I had protective tape on them for the couple of years I rode them.
Independent Fabrication Ti Crown Jewel--SOLD.
Santa Cruz Tallboy LTc XL with XTR, SOLD.
Moots RSL with DA 7970 Di2. 58.5cm top tube. $3,300.
2015 Tarmac Disc, 58cm. $4,000. Pro frame with DA and Ultegra Di2 and CLX 40 wheels. Zipp stem and Contour SL bars.
Will have normal carbon post (not the Canyon pictured) and original Specialized cranks. Pedals and cages not included.
Re: Clearing out: Kask Bambino. Zipp 202 and 303 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [chobbs] [ In reply to ]
Can you tell me more about your Santa Cruz Tallboy? Year? Approx miles? Any issues? Thanks.
Re: Clearing out: Kask Bambino. Zipp 202 and 303 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [skarkokc] [ In reply to ]
I am its 2nd owner. It is a 2012 or 2013 bike. This is one of the original long travel 29ers, with 135mm travel. Front fork is Fox 34 Factory Talas 140/110mm that was serviced 8 months ago. Fox RP23 CTD shock was sent to Push Industries 6 months ago for a rebuild and tune. I found the bike wallowed a lot, and the shock tune has significantly improved the behavior under larger riders (I am 180 lbs). Roval Traverse alloy wheels with 29cm inner bead width. Derailleurs: XTR 980 2x10 setup. Brakes: Avid Guide RS. 200mm front, 180mm rear. Specialized Command Post dropper. Cranks are older SRAM XX that have cosmetic wear. They came off an older bike. Specialized alloy bar, 780mm wide. Ritchey 80mm stem.
This bike is "high and tight" by current trends, which can be a good thing if you like your terrain twisty. I just got a new Hightower so this one goes. I ride mostly on the road. Strava says 994 miles under me, and the previous owner did not ride it much. It has been professionally maintained and has no mechanical issues. More pics here.
How many miles on the 303s?
Re: Clearing out: Kask Bambino. Zipp 202 and 303 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [Nochain] [ In reply to ]
Not sure how many miles on the 303s as they were used on a couple of different bikes, but not all the time. I mostly trained on some HED Ardennes and raced on tubies, but used the 303s for fast club rides in the Summer. Definitely more than 1,000 miles, but I doubt more than 3,000 miles. They still spin nicely and look great.
bumpity bump. dropped a couple of prices as well.
How much for the HED 3?
Re: Clearing out: Kask Bambino. Zipp 202 and 303 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [winston52] [ In reply to ]
Sorry, just updated the listing....$400 shipped for the H3.
bump
Re: Clearing out: Kask Bambino. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [chobbs] [ In reply to ]
what is the rim width of the zipp 202s? What width tire can it take?
Hey do you still want to sell the helmet? I want it and have sent several PMs
Re: Clearing out: Kask Bambino. Zipp 202 and 303 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [Veloracermike] [ In reply to ]
@Veloracermike--yes, the Bambino is still for sale. Apologies--I thought I responded to your PM on Friday while I was traveling but now I don't see it in my sent email, so probably a victim of lousy cell signal.
Re: Clearing out: Kask Bambino. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [nittiaj] [ In reply to ]
@nittiaj my 202s are the same rim as the current generation....only the hubs and spokes? have changed. The internal bead width is 16.25mm, external width is 24.6mm at the brake track and 25.4 at the widest point. I used Specialized 24mm tires on them and those set up nicely. You could use 25s but above that you are going to compromise the aerodynamics (if you care) and the weight (again, if you care). 202s are actually surprisingly aero at the lower yaw angles seen in real life.
Re: Clearing out: Kask Bambino. Wahoo Element. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [chobbs] [ In reply to ]
bump to add Wahoo Elemnt
How much for the ELEMNT
Re: Clearing out: Kask Bambino. Wahoo Element. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [Traphaus] [ In reply to ]
$250 shipped in the continental US.
Would you be interested in selling the rear 202?
Re: Clearing out: Kask Bambino. Wahoo Element. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [kanman] [ In reply to ]
looking to sell the 202s as a wheelset.
Re: Clearing out: Kask Bambino. Wahoo Elemnt. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [chobbs] [ In reply to ]
bump
Hi.Kask Bambino helmet still available for sale? Mind to ship me some pictures of the helmet, please? Thanks.
my email: seowfung@yahoo.com
lucas
Re: Clearing out: Kask Bambino. Wahoo Elemnt. Zipp 202 and Hed H3 wheels. 177.5 DA SRM. Ti XL road bikes. MTB. [mine75] [ In reply to ]
helmet still available....just sent you a link to more pics
bump
bump
bump with lower prices.
Sent PM about the HED h3.
