Hey guys,
SRAM Etap Front Derailleur, brand new in box. $400
Up for grabs is my Large 2016 Nitrogen. It was my race bike all season long, and has some minor wear and tear. It's a wonderful bike, and has been my favorite bike to date. There is some very minor paint wear inside the chain stays from running wide tires on wide rims, but it's all cosmetic. The bike has 3-4000miles on it, and will come with everything included in the original packaging. Here's the quick rundown of features. Looking for $1400 shipped, but open to offers.
Argon 18 Nitrogen Frame Set 2016
With cutting-edge aerodynamics and the benefits of Optimal Balance, this frame set has it all; providing light weight, rigidity and comfort. The Nitrogen will suit road and speed aficionados as well as those triathletes seeking the perfect balance between performance and versatility.This frame is is certified by the UCI and available in 5 sizes XS, S, M, L, XL.
Argon 18 Nitrogen Frame Set 2016 is extremely versatile as the SP-5000 carbon seat post is not only reversible, giving 72 or 76.5-degree effective seat angles; the clamp is also movable, bringing the seat angle to 78 degrees. This allows zero bottom bracket to saddle nose setback perfect for TT positioning. The downtube’s specific shape shields the bottles from the wind and enhances aero properties. The required rigidity must be correctly apportioned in the most highly stressed parts, primarily along the lower areas, while a measure of absorbency is needed in the upper region to ensure comfort, while reducing weight throughout. Argon 18 achieved this by maximizing stiffness with massive, asymmetrical chainstays as well as an oversized bottom bracket shell and head tube, while comfort was achieved by constructing the frame’s upper areas feature smaller, thinner tubes that absorb and dissipate vibration from the road.
Argon 18 Nitrogen Frame 2016 Features
Argon 18 Nitrogen Frame Set 2016 Specification
- Provides the benefits of an aero bike in an lightweight package
- Press fit 3D system - Allows for the structural extension of the headtube and improves aerodynamics
- Hidden aerodynamic brakes - Shrinks the frontal impact zone and promotes air flow
- Reversible Aero SP5000 seatpost - Provides greater flexibility for rearward and forward positioning
- Optimal Balance - Enhances the bike’s aerodynamics without weighing it down or sacrificing rigidity
- Frame: 990 g (includes medium frame, paint, and clearcoat; hardware [52 g] not included)
- Seatpost: Reversible (72°/ 76,5°) Aero SP5000 carbon; Road and Tri positions can both be obtained with the Aero SP5000 seatpost
- Seat clamp offset (road): -17,5 mm à -22,5 mm
- Seat front (Tri): +35 mm à +40 mm
- Bottom bracket: BB86
- Headset: FSA #39 (top bearing 1" 1/8 and compressor 1" ¼)
- Adjustable front derailleur hanger compatible with compact and oval chainrings
- Carbon dropout with replaceable forged rear derailleur hanger
- Monocoque carbon fork and hidden aero brakes
- Exclusive sheltered aero rear brakes
- Brakes: TRP/Argon18 TKB 137 - TKB 138
- Internal cables
