Dilbert wrote:
That's me in this relationship. So far in this house I fixed the
dishwasher (leaking water intake valve),
fridge (the Samsung flaw when the air ducts ice up because ice tray is in the fridge instead of the freezer),
TV (bad component in the power supply),
computers (many times for various issues),
Solar power for our backyard pond (easy because I built it), leaking
gutter (guy swore it was sealed - it wasn't),
caulking (hate it), her
car (blown fan motor controller board, a bad transistor on it), several
power outlets (backstabbing eventually fails please use the screw terminals!),
drainage (we had standing water in the yard),
heat pump (a short on the low voltage lines due to insulation rubbing VERY hard to find but easy to fix),
smart thermostat (output transistor on the yellow wire failed short and the heat pump tried to run when the furnace didn't. causing overpressure)
OTOH my wife can boil water? Maybe?
I pretty much attempt to fix anything I can. For the most part I can be successful with the internet and you tube. 99% of the time you are not the only one with the same problem. Case in point, woke up a couple of months ago to a puddle of water in front of the fridge (Kitchenaide). After I determined there was no leak, I cleaned up and wen to work. Pull out the controls print and start troubleshooting after work. Found that the fridge had two valves, both seemed to be shot. Bought the valves, still not working correctly. Buried in the internet, Electrolux sells a diode kit for their fridge valves. Sure enough, there is a diode on the print inline with the valves, 2 actually. More internet digging, I find the location of them, check them and they are not any good. $5 later I have 100 diodes at my door step. A little soldering with a heat gun later everything is back up and running. Also repaired the control board on the same fridge. I am sure it would have been a bunch for someone to come to our house to repair.
I have worked on AC and heating units at both houses we have owned. There isn't anything hard about it troubleshooting these items, there maybe hard problems, but the problem solving methods are typically all the same.
