Classifieds
Post deleted by dhoose
Re: New Reynolds AR 58/62 Disc Brake Wheelset; New Rotor Aldhu 155mm crank arms; Giro Empire SLX; Canyon CP10 Aerocockpit Carbon Handlebars [dhoose]
Specialized S-works SL Stem: Brand new, 120mm, 6 degree....130 grams on my scale.
Canyon CP10 Aerocockpit: New take off. Width of bars is 390mm, "stem" length is 90mm. Weigh a touch over 320 grams! Requires 1 1/4 steerer tube OR a shim to convert to 1 1/8 (under $10).
New items added.
New items added.
Bump
Hi To confirm: the Rotor ALDHU 155mm cranks - are the cranks and 30mm spindle...no chain rings?
Do you know if the ALDHU cranks only work with Rotor Chainrings?
Thanks
M.A.D. Multisports, NY (USA)
Re: New Reynolds AR 58/62 Disc Brake Wheelset; New Rotor Aldhu 155mm crank arms; Giro Empire SLX; Canyon CP10 Aerocockpit Carbon Handlebars [dvsho]
Correct, just the arms and spindle. You can purchase spiders that will accept 110 x 4 bolt or 110 x 5.
Bump...new items added.
