gymrat wrote:
You are missing the point.
Human interaction does not have to be 100% removed , as someone will need to fix, program, maintain the equipment.
However, that will go down as well because tech will improve flight efficiency. Next gen airplanes will fly longer farther and need less time being repaired because they will be easier to fix. So less ground crew will be needed.
However if the pool for conversation sake is 1000 pilots for commercial airlines today 2 seat pilot - co pilot. The Co Pilot is the redundant back up for "todays" technology. Tomorrow Tech, flight is guided from the ground and 1 pilot is in the air as the redundant, and maybe the 2nd redundant in the is a part of the flight crew.
So due to tech we have in this scenario:
* Removed 1 Pilot, 1000 pilots to 500 pilots
* So you have a 50% reduction in pilots
This is current evolution by the way.
DC 8 / 727 3 pilots - Primary, Co Pilot, Flight Engineer. I believe the original Large Jet liners 747 and DC 10's from the 60 had 4 pilots
757 / 787 has 2 pilots and no Flight Engineer (50% reduction)
Next Generation???
i agree with 100% of what you say here...except, i am not missing the point, i don't know if you understand the process to get a plane from point A to B. everything you said is correct but is all low hanging fruit.
i know nothing about surgery but i'm going to guess that for a heart surgeon doing surgery on some fat ass the hard part doesn't really start until you cut through all the fat. the fat cutting is the easy part, the real talent comes when they pick up the scalpel and start cutting around the heart. everything you've mentioned has been culled with a chain saw, we are now in scalpel territory.
i don't think the rate of change to get through the scalpel cutting is going to happen as the chain saw years were.
everything you've mentioned is automation, the article talks about AI. the automation in airplanes has gotten a whole lot better but is still far from a level i'm willing to let it go about on it's own. connecting AI to automation and trusting it, i believe, is still a long ways away.
the other issue that has not been address regarding one pilot is that the level of management of non-normal situations goes down dramatically with one person. 1/2 the pilots in the cockpit does not mean 1/2 the ability to manage emergencies, it's more of a 70-80% degradation in ability. i don't think people realize how much we depend on each other when things go tits up. all the pieces of the puzzle need to be looked at, automation, AI, reliability of systems and when the systems fail what is the resultant load on the human. i don't think the automation is at a level that is safe for one human. the amount of variables in actually moving planes around is too great for automation, AI and computers to manage at this point.
edit: 747s and dc-10s have always needed only 3 crew members to operate. now when flying over so many hours additional pilots are required due to the limits that pilots can sit at controls during a flight, but these are human limitations and have nothing to do with how many people are needed to operate the aircraft.
ΜΟΛΩΝ-ΛΑΒΕ
we're doomed
