This video caught my eye. Apparently old hand saw blades are useful for things other than folk art!
Lavender Room
Re: Slow Woodies - Pining for a Cabinet Scraper... [racin_rusty]
racin_rusty wrote:
This video caught my eye. Apparently old hand saw blades are useful for things other than folk art! The best way I've found to cut them up is to use a Dremel with one of the thin cut-off wheels. With a steady hand you can cut a straight groove and then keep deepening it. Then pop it in the vise, drawfile the edge and you're good to go!
You can also score the sawplate deeply with a carbide scribe, put it in a vise and snap along the scribe line. This is fast, but it leaves a deformed edge that takes a lot more filing to clean up.
Lee valley makes a sweet set of different gauges.
Long Chile was a silly place.
Re: Slow Woodies - Pining for a Cabinet Scraper... [BCtriguy1]
I can almost guarantee that Lee Valley is repackaging someone else's product and adding a premium for the privilege.
ETA: I checked LV their scraper prices aren't horrible. Might have to give 'em a whirl. Using an old hand saw is a bit of work. The handle that guy made may be worth the effort though regardless of the source of the scraper.
racin_rusty: May 30, 17 18:44
racin_rusty wrote:
I can almost guarantee that Lee Valley is repackaging someone else's product and adding a premium for the privilege. ETA: I checked LV their scraper prices aren't horrible. Might have to give 'em a whirl. Using an old hand saw is a bit of work. The handle that guy made may be worth the effort though regardless of the source of the scraper.
I was going to say. I think the set was between $20-30? How cheap do you need them to be! :-)
You can always look for an old Stanley #80 or #81; they are probably more comfortable to hold than that wooden handle. http://www.supertool.com/StanleyBG/stan10.htm
Can't help but comment on the filing technique in that otherwise excellent video: the dude really needs to learn how to drawfile. It's way faster - use the file the way he does to joint the edge, then turn the file 90 degrees and go to town. Drawfiling will give you faster metal removal if you bear down, and a better finish if you ease up on the pressure. Here's an example: https://www.youtube.com/watch?v=xM5xs-OBDCY (although I try never to use a file without a handle - I'm always fearful my 7th grade shop teacher will slap the back of my head).
