Classifieds
Re: FS: Cervelo P5-Six (Red/Wht | 54cm), Giro Synthe (Blk/Red | M), Pearl Izumi Singlet (M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [davews09]
Dumb question but how do you set up that dual cage hydration system on the aero bars?
Thanks!
Re: FS: Cervelo P5-Six (Red/Wht | 54cm), Giro Synthe (Blk/Red | M), Pearl Izumi Singlet (M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [bwood17]
Used an XLAB Torpedo mount, which I screwed in to the Aduro BTA mount. Then drilled a couple holes where needed in the Torpedo mount and installed the 2 torpedo cages back to back and cut one of the bottom tabs off so the bottoms come together without a gap.
bump
bump
someone must want a shiny 'like new' P5. Let me be your superbike depreciation shield.
Just had a deal fall through, so back up!
Bump for no aero penalty vs. P5X at +/- 5 degrees
Pearl Izumi top gone.
Pricing lowered for P-09 and Synthe
Re: FS: Cervelo P5-Six (Red/Wht | 54cm), Giro Synthe (Blk/Red | M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [davews09]
Pics on the Rotor Crankset. Size. thanks
I'm interested in the Giro Synth helmet. Can you take pictures of the inside of the helmet?
Re: FS: Cervelo P5-Six (Red/Wht | 54cm), Giro Synthe (Blk/Red | M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [dashtonn]
Pics are located in the link in the OP. Size is listed in the OP. Not sure where the confusion is coming from.
Re: FS: Cervelo P5-Six (Red/Wht | 54cm), Giro Synthe (Blk/Red | M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [chadm]
Hi I snapped a few pics of the inside of the helmet - same link add in the OP. Let me know of you need anything else.
davews09 wrote:
Pics are located in the link in the OP. Size is listed in the OP. Not sure where the confusion is coming from.just missed the link...thanks
No prob - anything else, let me know.
What type of lens is included with the LG P-09 - clear, tinted? thx
tinman
tinman
Re: FS: Cervelo P5-Six (Red/Wht | 54cm), Giro Synthe (Blk/Red | M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [tinman]
The stock lens, which is a smoke tint. (Not super dark and not clear.)
Re: FS: Giro Synthe (Blk/Red | M), Wahoo Tickr HRM, Rotor 3D+ (170mm), Garmin USB ANT stick [davews09]
Cervelo P5 and LG P-09 sold
