WTB: Velcro Fit Dots. Does any one know someone who sells the black velcro dots? We had thousands and we just ran out. I'd be happy to pay for a bunch if anyone has plenty? Thanks Dave
Fitters
Re: Ran out of Velcro Dots [ugojordy]
Google search is my friend
http://www.feinersupply.com/velcoins.html
Anne Barnes
ABBikefit, Ltd
FIST/SICI/FIST DOWN DEEP
X/Y Coordinator
abbikefit@gmail.com
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
You may wish to consider the marking dots supplied by Purely Custom, developed by Cyclologic.
Re: Ran out of Velcro Dots [ABarnes]
Hi Ann,
Thanks for this, I'm from Europe and didn't knew this company. Just to make sure that I order the right size. For your retul-use you order the 1/2" black loop from Feiner? 'Loop' is the correct side, right?
Are those black ones the same adhesive properties are Retul's black's? What do you use for the Retul's white? Or also the same from Feiner.
Thanks for your help,
kind regards,
Jeroen
kind regards,
Jeroen
Re: Ran out of Velcro Dots [tri-run]
Ah, well, I would look for a supplier nearer to you? Which country are you in?
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
Hi Ann, in The Netherlands. I don't mind the shipping if they are good.
Thanks,
Jeroen
Thanks,
Jeroen
let me reach out to my colleague in Eindhoven, I'm sure there is a supplier close to you.
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
Ha Anne,
Didn't realize you had contacts in Eindhoven :-), must the guys from EnergyLab. I tried some local dots but none of them had the same 'power' to stick on skin or for that matter clothing that was strong enough.
So if you use them from Feiner and they work I happy with those unless indeed your contacts in Eindhoven have a closer source. Anyway, your help is well appreciated.
thanks,
Jeroen
thanks,
Jeroen
We use Uline for our restock
Thanks, but in the mean time ordered a guru dfu. Sold my retul equipment, at least the most of it. Also getting the guru ror software, seems to quite accurate. I talked to someone that ran guru ror software as well as retul on some subjects and the ror was pretty remarkable accurate.
I will see in the next couple of weeks.
